Cactus Jack
We hear it all the time, "Warmoth necks are playable right out of the box." Yes, they are playable and most folks will bolt them up and never look back. However, to achieve the best results I recommend folks search and read every post from forum member Cagey they can find. The time invested gleaning his insight regarding all things necks, will pay dividends for years to come.
I normally level, crown, and polish the frets on all of my necks. I opted to bolt this one straight on, in part because I wanted to finish my build, but also because Warmoth necks are "playable." I tried playing it as is for a few weeks, but I could feel Cagey staring at me shaking his head in disappointment
. Also, I could feel the fret ends grating my hand.
Below is an example of the old Dan Earlewine fret end test. Essentially grab a dowel and run it back and forth over the fret ends to see if they're sharp. As you can see, the initial results were not good. However, after an hour of applying Cagey's craft the results are much better. While the neck was technically playable before, it's now enjoyably playable, and even though it's not perfect, it's noticeably better. Folks, if you want to maximize your playing experience, and dramatically improve your instruments performance, call on Cagey.
Straight from Warmoth fret end results:
Cagey time:
Thanks Cagey!
Cagey time:
Thanks Cagey!
