Hi,
I purchased a Schaller Roller Bridge which I am very happy with, but a bit confused on whether or not I need to connect it to ground. There doesn't seem to be any way to effectively attach a ground wire or solder wire to it, even after removing the finish. Now I'm wondering if grounding it is necessary as I'd think Schaller would provide a place on the bridge to do so. The wiring plan I'm using calls for a Gotoh Tremolo which is definitely grounded. Since I'm using a different bridge than called for in the plan I'm a bit confused and haven't been able to find the answer in any online literature....
