fdesalvo
Ha! Well, not exactly. Being so impressed with the Studio Chorus 210, I decided to expand my quest for it's bigger brother. Behold the Classic Chorus 212! Sporting 2x75w power sections feeding a pair of massively-magneted 12" drivers. Very JBL. It's everything the little guy is but, so much more. More depth. More projection. More stereo width. More!
After receiving the amp with an intermittent input jack, I began exploratory surgery shortly after de-bar-smoking the tolex. It wasn't all rainbows and unicorns, though. I have been forced to use a butane iron and in a careless moment, misdirected the exhaust port and roasted one of the gray push-button caps on the bright switch. Oh, well, a grand excuse to buy new parts!
I found a few cold solder joints and some weathered potentiometers, which I have replaced. Also replaced the power cord due to a snapped ground lug at the plug end. I decided to remove all old heat sink compound and apply a high performance compound, which will last a good 8 years. I'm waiting on the monster filter caps to arrive, so I can button her up and carry on with life. Pretty impressed with the build quality and choice of materials. I can see why these teal-striped Peavey's are so desirable.
Enjoy!
Offending cold solder joints at inputs
Massive filter caps
What?? All ICs, but one are SOCKETED.
Power transistors nestled into a heatsink and massive heat extractors. These were all disassembled, cleaned, then coated with new heat sink compound. Apply as little as possible. Apply a thin coat to one surface, mate both together, disassemble, then wipe one surface clean and reassemble.
Old stuff..
New stuff
Better together
Pots
