Binding on neck available?
Leftystrummer
I was building a custom Jazzmaster neck and I noticed there was no binding option . The neck I am replacing has binding that matches the cream-colored pickups and I was hoping to recreate it. Does warmth offer binding on necks?
Yes, we offer binding. For the option to be visible/available you have to select "Modern Construction".
Does that mean you can't get the truss rod that adjusts at the headstock with the binding option??
Correct. Modern construction has a heel and side adjust mechanism.
The exception might be a modern tiltback headstock neck which adjusts at the headstock. But as far as I know, that is not an option for Jazzmaster necks, but it might be possible off menu if you called or emailed sales.
Anyone know if binding is available on 7/8 warhead necks? I think I saw somewhere that its not available on 24 fret necks.
