C
		Cederick
The guitar I'm working on right now is HSH, and I want the single coil to be toggled by an on off miniswitch (well, on-on)
So I'm stuck at where the switch turns off ALL PICKUPS, even tho it's not even connected to the others...
Both humbuckers goes to individual miniswitches for series/parallell/split or something like that, and then to a 3-way switch.
The single coil is supposed to be separate from those, and be able to turn it on and off in any of the humbuckers options...
And I simply dont get it! The singlecoil is connected to the miniswitch and then it's going straight to the output.
Is it a grounding problem?! Or have I just soldered it all incorrectly? :help:
