Beast is coming
Fat Pete
Gave in to temptation and pulled the trigger on my third piece of sweet Warmoth candy!
I wasn't initially convinced about the Diamondback design but it's been growing on me as some very nice examples have been popping up in the showcase. It had to be this one though.
It's not easy to capture what the finish really looks like but this gives an idea:
I tried to find an alternative to this neck... but couldn't. Dark Indian rosewood, black ebony board, no inlay, ebony headstock veneer, pearloid binding, SS6105 frets, Graph Tech nut. Heavily discounted as a 'Screamin' Deal' but still pricey (I couldn't quite get the supposed $833.00 built to order price to add up). Just one of those occasions when you see something and the whole plan presents itself.
The ebony veneer looks darker in the flesh and is super smooth!
This is trying to show the edge of the veneer - very nice workmanship, Warmoth.
Likewise, here's the scarf joint.
It looks like this must have been a customer return as some fret dressing work has been done. It hasn't been screwed to a body and no tuners have been installed, so happy enough so far.
Although this is intended to be a quick showcase items project, there is some work to do and the pickups will take a while to arrive, so look out for a work in progress thread when there is some...
Well, Pete, I figure if we're patient with you, eventually you'll loosen up, get a little bolder, and try something with some COLOR in it!!!!! YIKES! That is fascinating--can't wait to see where it goes!
Well, clearly, Pete, you're a fine practitioner of the art of building awesome guitars through the sheer majesty of opaque paintjobs.  Way to show us how it's done.
Thanks for the kind words!
Hardware is coming in, just a bit of a wait for Doug's jewellery and more of a wait for a set of At The Creamery pickups...
In the meantime it's measuring, hours of (mostly unnecessary) design tweaking, paper mockups etc etc...
I know that wait all too well...  Which pups did you go with?
I'm trying a set of his Double Tracks - heavy looking blade humbuckers but made to whatever spec you want - mine will be fairly low output early PAF-ish.
That sounds like a great match!  I look forward to hearing your initial impressions.
There are greens and then there are greens. This one really looks great. That neck will be a fine compliment for it.
