Hey, well as you can see from my assembly post i have got all the parts for my bass, but however i need help on what you suggest i do myself, and what i dont do myself so heres the list
Also my original plan included a 3 way toggle switch which warmoth couldnt drill for, however with a pre painted body do you think this is an ok hole to drill, most likely by a professional luthier?
If ive missed any steps out then include them in any reply.
just want to get an idea for what you think i could be able to do myself with some patience and concentration.
This is my first time putting together a bass Cheers
- Attach Tuners to neck (half done/ one badly but can be finished properly)
- Attach neck to body
- Strap holder screw holes need drilling then attaching
- Pick ups need installing
- Bridge needs installing, all holes pre drilled for right bridge
- jack plug needs screws for plate drilled for then attached
- Electronics require installing then soldering together using Wiring Diagram approved by you guys beforehand ages ago
