jackthehack
Epic Member
See pics below; is that pilot hole pattern stock for any known bridge, or did somebody smoke crack and go nuts with a drill?
SkuttleFunk said:hey Jack,
without physically knowing the bridge I can't say with 100% certainty ... but option #2 sounds OK so long as moving the bridge forward that 1/4" doesn't ruin you ability to intonate the lower strings. I would have concerns if you were instead thinking of angling the thru-body routes towards the butt end.
all the best,
R
stubhead said:If you can cover a length of 34 3/16" (treble) to 34 7/16" (bass) it ought to work... of course 34 1/8" - 34 1/2" would be even more comfy. Quick! If anyone has a low E longer than that,
stop him, before he drills again....![]()
max length adjustment for low E string would be 34 9/16ths, so I guess it should work?
