chuffed-addick
Hi All,
Found this place a while ago and some great advice, so thought I'd sign up and post my question.
I've now sprayed 2 guitars, made the usual impatient mistakes and had runs and overspray/ burn through, all of which I've solved or learnt from.
The one thing I'm having issue with is the clear coat I've used. It just doesn't seem to have hardened properly! It went on ok, and left it at least 3 weeks after spraying before sanding orange peel off and buffing. Since then it seems that even standing the things on carpet leaves a mark on the finish, not deep just enough to be noticeable. one of them has got a mark from where the cliplock strap has rested on it in the case too.
I wondered if anyone would know why this is? only thing I can think is it didn't get hot enough during the buffing stage as have been doing all the work by hand. Would this affect it? Any help greatly appreciated as can't find anyone else having this issue!
Here are pics of the finished guitars out of interest.
first one, bit blurry but british racing green
Second is bit of fun I had with masking tape!
