exaN
I'll be starting to work on my new Soloist very soon and will post updates here.
Specs:
I'll be using the neck from another guitar for this one, so the tuners are already installed and the frets should be fine. I'd like to build the whole thing myself and I'm trying to figure out the bare minimum I need to do so. I live in an apartment so I have very limited space to work on this. All I really have at the moment is a soldering kit, some screwdrivers, a hammer, pliers and cutters. Any suggestions to add to this would help a lot (but remember, bare miminum :sad1!
List of things I'll have to do:
I'm also trying to find a place in the Bay Area to laser engrave a logo on the headstock rather than using a decal, but I've had no luck finding place that has a machine big enough for a guitar neck. Does anyone have a good place for this?
I'm excited for this since the only guitar I built entirely myself was my first Warmoth, but got help from my dad (I was only 19, now 28!). Will post updates when I get anything done .
Specs:
Model: Soloist
Orientation: Right handed
F-Holes: None
Scale: 25-1/2"
Wood: Quilt Maple on Black Korina
Rout: Rear Rout
Pickup Rout: Humbucker (Wood Mount) (N), None (Middle), Humbucker (Wood Mount) (B)
Controls: V-X-T-5 (Strat®)
Bridge: Recessed Schaller Floyd Tremolo
Stud Install: No Stud Install
Jack Rout: 3/4" (19mm) Side Jack Hole
Neck Pocket: Strat® Shape
Contours: Contoured Heel / Tummy Cut / Forearm Contour
Battery Box: No Battery Box Rout
Binding: Natural Masked Accent
Top Finish: Aqua Marine Dye
Back Finish: Transparent Blue
Finish Type: Gloss Finish
- Full Schaller Floyd install (including stud install)
- Full electronics install, 2 humbuckers (wood mounted), 1 volume, 1 tone and a switch for coil splitting (will have to drill hole)
- Strap buttons install
- Some nut filing for the higher string gauge
- Action and intonation setup
