Steve_Karl
Hi there,
Tell me about the tone and sustain?
Which one do you have (model number) brass/brass ... brass/steel ... steel/steel ... etc?
Thank you!
Or if you're willing and able:
Record a quick audio demo?
Please, no amps or amp sims. I need it to be direct into the sound card. That's the only way to get the real sound of the guitar and hear how it sustains without any help.
Also, please tell me what strings and guage you're using and also what pickups and what kind of pick.
You don't have to play anything special and you could, if you want, just strum across all 6 strings and let it decay,
and then maybe each string individually and let it decay. Open strings are fine in both instances.
Of course if you want to play something then fine but be aware I'm looking for sustain length so please keep that in mind.
Thank you.
I do have a G&L with a Kahler flat mount on it but it replaced the original G&L tail piece and I suspect that the bridge contact
to the body isn't what it should be. It's ok but not a lot of sustain.
Thank you!
Steve
Thank you!
Thank you.
Thank you!
Steve
