Amplifier kits
DOOM
What is a good amplifier kit between 300 400 dollars? I don't have any experience in this area, so any other advice is helpful as well
Hmmm.  Like everything else you get what you pay for.  The Weber kits are fairly inexpensive, but they don't have the best components (bad jacks, not so great caps, etc).  The Mojo tone ones are fairly expensive, but trend toward cork sniffing.  Between the two I'm liking TubeDepot for a good compromise, but you can build a great amp with the Weber kits if you know what's good and what to replace.  Also, amp kits vary in price due to the size and power of the amps in question.  For example, a tweed 5F1 is not going to be the same price as a Marshall JTM45.
What amp were you thinking of building?  Maybe we can guide you better knowing that.
Weber makes good kits, maybe a little above your price range:
https://www.tedweber.com/amps/kits
They don't really offer instructions other than the diagrams.
Also, the first amp I built was an AX84. They used to sell kits, but you'd have to source the parts yourself now. It's a great resource either way and there's a lot of stuff there that would be helpful to read regardless of who's amp kit you're building:
https://ax84.com/archive/ax84.com/index.html
