Alba Guitar Beads
thanks. I just bought a set for my classical guitar.
Be aware that the delivery is from the UK and eventually USPS gets it and there is ~signature required~ .
HOWEVER, we are allowed to 'authorise' an other person to sign for the package.
So I printed up a page that authorised my mail person, delivery person 'carrier' to sign for the package,
I signed the bottom of the printed page, taped it above my mail slot and that worked. My carrier signed for it.
noted thanks.
I had a set of those on my nylon string for a while and ended up ditching them because I found it easier to tie them the traditional way.
On a guitar where you must have a "ball-end" I'll bet they are a godsend.
I am confused. I know that several string makers have ball end Nylon strings. Is there some reason you wouldnt just use those?
I tried the Ernie Ball ball end nylon strings - the E and The B balls broke of in less than a week.
They were plastic balls.
I just assumed the other makers ball ended strings would be just as poorly made.
I also thought the sound and feel of the EB ball ended were not nearly as good as the
D'Addario EJ27N that I eventually got - based on a recommendation by a friend. Price also was better on the D'Addario EJ27N.
These Alba Beads will also make it much easier to try other different brands and sets of strings.
What interested me other then being another guitar gadget, a few years ago I ordered one set of D'Addario nylon strings from Amazon. They sent 10 sets of Pro Arte's instead, so these might make faster/easier to string up.
Update:
Last week I put a set of D'Addario Pro Art on using the beads. Pretty easy.
I discovered that the only string I want to do a double loop-through is the High E.
I didn't like the feel of the Pro Art compared to my usual set which is the D'Addario EJ27N
. . . probably because I'm very used to them, so I restrung with EJ27N just now and the second time with the beads is
much easier.
I'm just, right now, doing the tune sharp for 10 minutes (one string at a time) trick to stretch them into a more reliable stability.
Hi E up to about F# or G
B up to D or D#
G up to C
D up to E or F#
A up to C or D
Low up E to A
I use the timer on my mobile phone and leave them tuned sharp for 6 to 10 minutes - one at a time.
Then re-tune to correct pitch and do the next string.
6 minutes for steel strings is plenty and makes them perfectly stable after the first stretching.
10 min. for nylon - then just a bit of re-tuning for the next few days until they're as stable as nylon strings can be.
So, bottom line for me is - I like these beads.
It's a lot easier than tying a brass ball onto the string end.
Update:
much easier.
B up to D or D#
G up to C
D up to E or F#
A up to C or D
Low up E to A
Mine set arrived on Thursday, so it took 9 days to receive. Strung up my guitar with a new set w/ these beads. Good idea to do the double-loop on the high E.
