Ace Flibble
Not terribly worthy of a thread just yet, but starting one gives me an excuse to throw out a cry for help and grab some hardware opinions too
So, this turned up an hour ago
(that's all you get for now as my proper camera seems to have kicked the bucket)
'Tis darn purdy. The White Pearl finish is exactly what I'd hoped for. I've always been disappointed with regular white finishes, how due to sunlight, regular lightbulbs or just a general lack of light they always look falsely aged even if they're supposed to be pure white. The slight metallic sheen of the white pearl keeps it looking bright white no matter what. The edges in particular come off looking razor sharp.
Great weight to it as well, on the showcase it was listed at about 4.5lbs (might have been .6, whatever), pretty standard for alder I thought, but in my hands right now it feels about the same weight as my fully chambered 3.7lb Korina Thinline Tele body and significantly lighter than my alder Strat (which is somewhere in the four and a half pound region itself).
I am having one slightly major problem though: I had assumed that CTS pots would fit, since CTS fit my other Warmoths. However trying out a dry run, it seems as though the control holes are a clear 1mm too small for CTS pots. The threaded portion of the shaft isn't just a tight fit - it plain doesn't fit at all. Since I have no way of enlarging the holes myself (I'm armed with a power drill, a hammer, two screwdrivers and literally nothing else) and since I'm in the UK, making returning a pain in the arse, it looks like I'm going to have to go with Alpha pots instead. Not a massive problem but a bit of a shame and it means I'm going to have a helluva job getting these inch-fit knobs to go on right. Unless anyone has any nifty ideas how to wedge the CTS pots in there?
Also it seems as though standard short shafts won't reach through the top but long shafts end up scarily close to the cavity cover. Not sure what's going on there either.
Now for the part where I break everbody's hearts, the mock-up for this body:
Hardly a classic, I know. But it's completely me - I love white guitars but I also love making everything purple and black, so a white guitar with purple & black hardware is perfect. Once this one is done I plan to get cracking on another purple monster too.
Neck is going to be purpleheart with an ebony fretboard, 24.75" conversion, 12" radius with a compensated nut. Never even been in the same room as an unfinished neck before, I'm expecting good things.
Probably going to be a Standard Thin back but I might go for '59, ideally I'd have something inbetween so it's a toss-up whether I go for something a shade too flat or a shade too thick. Hint hint Warmoth: make a neck that is actually like the Fender necks!
Also undecided on the fretwire. I like the idea of steel frets but none of the sizes are quite right for me. Going to flip a coin between my safe regular 6150 or taking a risk on SS6115. Anyone got any input on how 6115 size wire feels compared to other, more common fret sizes?
Using Sperzel tuners because on my last two Warmoth necks I drilled the holes for the string retainers kind of... wonky. Accuracy is not my middle name. That said I've heard many horror stories about installing the Sperzels too, so I've got a spare set of Planet Waves on stand-by.
Pickups are going to probably be a set of Bare Knuckle Cold Sweats, or possibly a Cold Sweat bridge and a Riff Raff neck. Hoping they'll be worth it whichever way I go.
