Hi guys,
I have been thinking about putting together a warmoth and found it hard to decide between these two.
On one hand, 7/8 bodies are a bit smaller and the neck has 24 frets. I don't think I would use the 24th fret and that's what have been keeping me away from this choice. The neck pickup is moved to accommodate 24th fret, a compromise for something I don't use.
Joe Satriani talks about this in this video at 2:00min : https://www.youtube.com/watch?v=XttCY0mw6AI
I have been told by reputable guitar builders in my last topic that neck pickup position doesn't matter that much. That makes sense as the string length basically changes as you fret the notes. So at most, you will get the tonal spectrum you would have in any fret, roughly in two frets higher.
On the other hand, seems like the conversion neck is just a 24 3/4 neck. and comparing pickup positions on a humbucker loaded telecaster they seems to be at the same distance from the bridge as a 24 3/4 guitar, even though the body scale is 25.5(whatever that means).
So if I get a conversion neck, I'll get same pickup placement as a les paul and a 24 3/4 scale. Is this correct ?
Could you guys tell me which one you would choose and why? Or even better, if you have played a 7/8 and a regular with conversion side by side, could you please comment on the differences and pros/cons of each.
