S
swarfrat
So I'm a big P-bass fan. Gimme a P-bass with a pick for rock n roll. Not mud, not piano, just articulate fat punchy THUD. And I want a 5-string P, but with skinny string spacing (die hard pick player) and oh I wouldn't mind an offset waist.
I'm a fan of extended scale on guitar, but I'm kinda torn on the bass. Does it matter? FWIW I'm playing D'Addario Tape wound EBT92-5 (and currently throwing away the 50 on top). I'm not even sure it needs to be a Warmoth - I'd grab a squire if it did everything I wanted. The hardest combination seems to be string spacing and pickups. As soon as you route it for the split coil, they assume you want a separate zip code for each string.
Anyone who's gotten a 35, was it everything you ever dreamed? Is it only for piano bass tones, or does it help with the slightly scooped articulate P sound? Is there anything that really nails the P-sound in another form factor? If I get a Gecko, do I need a narrow neck if I'm getting a narrow bridge? I'm not really wanting a 2nd pickup, but won't throw away an otherwise ideal bass because it has one. Is there something that fits my bill off the rack?
