A few days before the Warmoth Sale ended I went for my second build. I almost couldn't decide on a color between amber, vintage or yellow until I saw how great the yellow on Valentina turned out (http://www.unofficialwarmoth.com/index.php?topic=10556.0) came out in another thread. Since this one needed a paint job it took 3 weeks but it finally showed up.....It was worth the wait.
Here are the specs:
Model Standard V
Orientation Right handed
Core Wood Swamp Ash
Top/Rear Rout Rear Rout
Neck Pickup P90 (Neck)
Middle Pickup P90 (Middle)
Bridge Pickup Humbucker (Brdg)
V Controls Toggle (V)
V Controls Volume 1 (V)
V Controls Volume 2 (V)
V Controls Tone (V)
Bridge, Fixed Rec TOM/Arch String
Output Jack 7/8" Side
Countoured Heel Contoured Heel
Finish Transparent Yellow
Scale 25-1/2 in.
Battery Box None
Headstock V
Construction Warmoth Pro Angled
Orientation Right Handed
Shaft Wood Mahogany
Fingerboard Wood Pau Ferro
Nut Width 1 11/16"
Back Contour Standard thin
Fretwire 6130
Tuner ream Planet Waves(13/32")
Peghead Veneer Pau Ferro
Fret Number 22
Radius 10-16" Compound
Inlays Mother Of Pearl Dots
Nut Install GraphTech TUSQ
Neck Finish Vint Tint Satin Nitro
Scale 25-1/2 in.
BPSB Barpack P90 Set, Black (Bluesbar & Jazzbar) $169.60
1 ES1B Electrosocket with Switchcraft Jack, Black $12.00
1 TOM1B Gotoh Tune O Matic Bridge, Black $22.00
6 GSF1B Guitar String Ferrule, Black $5.52
1 IG88 Top String Ferrules, Set of 6, Black $3.75
1 NP1P Neck Plate Pad, Black $2.00
1 HBRT1B Tall Humbucker Mounting Ring, Black $3.50
1 BBQZ4 BBQ Bucker, Zebra, 4 Conductor $92.80
1 PW33B Planet Waves Auto Trim Tuners, Set of 3L+3R, Black $68.00
3 BK1B Barrel Knob, Black $6.00
1 SLP1B LP Toggle Switch, Straight, Black $11.50
2 PP500 Push Push Pot 500k with DPDT Switch (On-On) $24.00
1 CTS500 500K Pot, By CTS $5.00
1 S8 Neck Screw, Set of 2+2 for Contoured Heel, Black $3.00
1 S17 Humbucker Mtg Screw For Plastic Rings, Dozen, Black $3.60
1 S20 Humbucker Height Adjustment Screw, Dozen, Black $4.20
1 CAP2 Capacitor, Ceramic Disc, .022uf, 50 Volt $0.50
1 WK1 Wiring Kit , (1 ft ea of Black, Red & White Wire, 3 ft of Coaxial Wire) $5.95
1 LPSP1B LP Switch Plate, Black $1.25
Here are the specs:
Model Standard V
Core Wood Swamp Ash
V Controls Tone (V)
Scale 25-1/2 in.
Battery Box None
Headstock V
Shaft Wood Mahogany
Nut Width 1 11/16"
Fretwire 6130
Fret Number 22
Scale 25-1/2 in.
