tfarny said:On neck heaviness: if you pick light tuners and place your strap buttons carefully, I imagine a medium weight body would be fine. Since the cabro is rear routed, you can easily epoxy some lead weights near the output jack to help out the balance as well. I think it's a solvable problem.
12 string rear routed dual filtertron strat? Maybe sparkly red w/binding? Could also be something huh.
AprioriMark said:tfarny said:On neck heaviness: if you pick light tuners and place your strap buttons carefully, I imagine a medium weight body would be fine. Since the cabro is rear routed, you can easily epoxy some lead weights near the output jack to help out the balance as well. I think it's a solvable problem.
From actual experience, a 6 lbs 4 oz body with pickups and hardware was still neck heavy with vintage tuners and several strap button placements. That's why I gave up and went Strat body for the 12, even though I really wanted it to be Tele shaped. I'm just warning you... if you're going to play it a lot, there's a reason you don't see Tele shaped 12s very often.
-Mark
Alfang said:speaking of the monkeys, they have a few songs that I really like, I know they didn't write their own stuff, nor did they play instruments on their songs, in fact they didn't sing on the first few songs, whatever, I like their stuff.
Michael Nesmith is an idiot by the way.
Alfang said:Michael Nesmith is an idiot by the way.
tfarny said:A 12 string strat or JM would probably be cool too. But still, a 12 string with TV jones pups and a tele shape!
In other news, Lollar is now going to sell Fender style WR humbuckers. So - Hmmmmm.
drewfx said:I will say my Rosewood Twelecaster (it's really a thinline though) has some neck dive, but I usually play it sitting, so I don't really care.
He's not had them as an option on the site for long, but I think they were a call-and-ask option before.AprioriMark said:tfarny said:A 12 string strat or JM would probably be cool too. But still, a 12 string with TV jones pups and a tele shape!
I thought he had been? A friend of mine has a Jazzmaster with Lollar WR.
-Mark
