But nevertheless, it rocks!
What am I talking about?! Well... I'm talking about the 'coming to life' progress of my 2 crimson guitars-guitars.
specs?
purpleheart back, Rosewood top, pau ferro / bubinga neck (9 ply) with ebony board with snakewood binding, with maple purfling, with 7ply wood binding on the headstock and body, with easy access heel, 3 humbuckers, ToM-bridge (custom-made, steel with steel saddles, or aluminium casing with brass saddles, have to figure it out though).
Padouk back, wenge top, bocote/wenge neck, and all the specs of the first one.
Superspecial features which make these guitars truly unique, besides my woodchoices:
the backplates are cut from the actual back.
the headstock is MY design
the neckshape is my design
the way the backplates were cut, is my design
the wiring is my design
the trussrodcover is recessed
the outputjackplate is recessed
the knobs are wood
the pickuprings are wood
wood headstock-veneers
deep set necks
easy access heel, my design
my pickup-designs, again, as usual
non-weight relieved
special topcarve (deeper and more scooped than on anything I've seen before).
It took me just 3 months to figure out the basic specs, aka: which woods. but it took me 18 months to figure out the tiny details!
but, here we are. the guitars are far from being finished, but the tops are carved, and all the major woodwork is done.
The Rosewood top.
The top started out just fine, but later, after planing it down, the top had a crack underneath the first millimeters of wood. But the luthier repaired it. I dont know what he did, cause you can't even see the cracks or the fillers (if there are any!). but I'm glad we sticked with this top!
Both guitars, their backs. me like!
Just after being planed, some weeks ago. The Luthier will superfine-sand them again to get the colors super-vibrant, just as you see it here.
The tops. I really like the woods
its starting to look like 2 guitars!
Victory! the 2 headstocks seem to be a bit like a gibson-head if you look at them with first glance, but if you look better, you see what it really is.
The headstocks still have to get binding and inlay, the bodies have to be bound on the top and back, and then? laquer! the bodies are going to get nitro-coats. We wanted to do some oil at first, but it won't work with the wenge top that well. I want a slightly glossy look, and thats something you can't do with oil. More importantly, we're going with a lacquer that has a UV filter in it, so the woods won't discolor over time.
specs?
the knobs are wood
deep set necks
non-weight relieved
The Rosewood top.
