I have a couple headless guitars with zero frets. They're OK, but if you bend notes near the nut, the strings move around and don't quite come back to where they were. The problem is that the support for the string spacing is 1/2 an inch from the zero fret. If you have the setup that has a nut just behind the zero fret it would probably prevent that, or at least minimize it.
